PLM Guidance
PLM 12 Yeld Sensor
September 14, 2018 3947
Data Mapping
in Ravenhill PLM Guidance by Stewart Davidson
Data Mapping Records of work done can be logged by the displays and taken back to the office for analysis / record keeping: Intelliview IV displays on tractors & harvesters can automatically log in the background useful info such as; crop yield, moisture,… READMORE
24909738 1977774285794156 3061282115371280892 n
September 14, 2018 3983
ISOBUS Task Controller (ISO TC)
ISOBUS Task Controller (ISO TC) The next evolution from TUVR: An Isobus implement can be connected to either an Intelliview IV, XCN-1050 or XCN-2050 display, showing both the implement operating screen and controlling rate / section at the same time via GPS… READMORE
PLM 15 Agronomy
September 14, 2018 4148
Serial Rate Control / TUVR
Serial Rate Control / TUVR The GPS display can take over control of your compatible fertiliser spreader or sprayer control box Depending on the implement capabilities, this can alter the rate according to prescription maps and/or section control This can… READMORE
38774651 2121683761403207 8005563669578514432 n
September 14, 2018 3895
New Holland Intellisteer System
New Holland Intellisteer System Our fully integrated, high-performance solution on New Holland machinery: Uses the integrated Intelliview IV display Utilises the original Intellisteer-ready valves & steering sensor Highest performance and accuracy Simplified… READMORE
27857975 2006559962915588 8476959971963694824 n
September 14, 2018 3970
Autosteer Ready System
Autosteer Ready System Aftermarket option for vehicles with factory autosteer-ready systems: Available for the FM-750, XCN-1050 and XCN-2050 displays Utilises the original factory fit steering valves / sensors - regardless of brand Highest performance and… READMORE
PLM 12 Hydraulic Valve HD
September 14, 2018 4231
AutoPilot Hydraulic Aftermarket System
AutoPilot Hydraulic Aftermarket System High-accuracy solution for machines that are not autosteer-ready: Available for the FM-750, XCN-1050 and XCN-2050 displays Uses hydraulic valves and pipework specifically designed for each machine High performance using… READMORE
38801316 2121694878068762 1795368558193016832 n
September 14, 2018 4221
Ez Pilot Pro Assisted Steering System
Ez Pilot Pro Assisted Steering System New high-performance assisted system designed for the XCN-1050 display & NAV-900 controller: High accuracy from the column-mounted SAM200 steering motor Uses the NAV-900 guidance controller for reduced components and… READMORE
PLM 12 EZ Pilot
September 14, 2018 3964
Ez Pilot Assisted Steering System
Ez Pilot Assisted Steering System The next step from your lightbar unit – add hands free steering and let the motor follow the line: Compatible with the FM-750 and XCN-2050 displays Reduce overlaps and increase productivity whilst letting you concentrate more… READMORE
PLM 12 IntelliView IV
September 14, 2018 4098
New Holland Intelliview IV
New Holland Intelliview IV Our integrated display option packed with the following features: Clear 26.4cm touchscreen display Compatible with New Holland tractors, harvesters and implements Monitor and control vehicle functions and performance Tractors: HTS2… READMORE
14233046 1766310923607161 844926007018592202 n
September 14, 2018 3892
XCN2050
XCN2050 The flagship display in our aftermarket offering: Large Android-based 30.8cm high definition touchscreen display Rugged tablet-like display designed for agricultural environments Choice of Precision IQ or FM1000+ interfaces depending on user needs Use… READMORE
35545743 2071000229804894 1222395164715122688 n
September 14, 2018 4133
XCN1050
XCN1050 Our latest aftermarket display built with flexibility and ease-of-use in mind: Android-based 25.6cm high definition touchscreen display Quality, rugged device designed for agricultural environments Roof-mounted NAV900 combined receiver & guidance… READMORE
PLM 12 EZ Guide 250 02
September 14, 2018 3918
Ez Guide 250
EZ Guide 250 Our entry-level lightbar unit boasting the following features: Rugged yet compact build with 10.9cm colour display Simple setup – a few button presses and you’re ready to go Easy to follow with 15 bright LEDs to guide you Multiple patterns… READMORE
PLM 12 FM 750
September 14, 2018 4083
FM750 Lite
FM750 LITE A feature-packed lightbar unit with upgrade potential: 20.3cm vivid touchscreen display Intuitive setup and use 27 bright LEDs to guide you on your way Multiple patterns including AB, curve and headland Field and coverage data can be saved to USB… READMORE
June 02, 2016 5622
PLM Specialist PLM Page
New PLM Specialist for our Scottish Depots We are pleased to announce Steven Morrison as our new full-time PLM / Product Specialist for our Scottish branches. Ravenhill realise the need for a dedicated support in this rapidly growing and exciting area, and… READMORE
Go To Top
